How to post OneDrive pictures into a PHPBB3 forum
Non Hi-Fi or music topics
flatpopely
Post by flatpopely » Fri May 06, 2016 2:33 pm
So after much searching and teeth gnashing I have done it.
1. Login to your OneDrive account
2. Navigate to the picture you want to share.
3. Right click on the photo and select 'Embed'
4. It may ask you to 'generate' code or will automatically do it for you.
5. Select and copy the URL e.g.:-
https://oiw34a.bn1303.livefilestore.com ... pmode=none
6. Go to your forum and paste the URL between the following tags, the tags are at the top and an example is shown below them - just paste your full URL were the https://etc. text is.
I cant actually put the tags in here as text because your browser will assume there is a picture between them and not display them!
NO SPACES, just put the URL between the brackets ]URL HERE[
Your image will now appear embedded in the post, like this:-
Flat Earth rocks with PJC!
(Porcupine Tree are the new...'insert fav prog band here')
LP12/Ittok LVII/Tranquility/RubiKon/ASAKA/RadiKal
Soundblaster X-Fi HD
SONY CDP 338ESD
SONY TC-K444esII
JVC AX-Z1010TN
Linn SARA (YNWAN bespoke build)
